HN: Titanove matice GR5
Fórum: Společné nákupy
PříspěvekZaslal: 1.5.2013 , 13:06  Naposledy upravil infinity dne 1.5.2013 , 13:12, celkově upraveno 1 krát. Citovat
Byl by zajem o matice z praveho titanu? Bohuzel vyroba 20ks v CR by vysla na cca 400kc/1ks matice (pri vetsim odberu)
+/- stejna cena by vysla i od levnejsich dodavatelu typu blox:
Jedna se o pravy Titan GR5, pro technicke jedince prevzato z wiki:
citace:
Grade 5, also known as Ti6Al4V, Ti-6Al-4V or Ti 6-4, is the most commonly used alloy. It has a chemical composition of 6% aluminium, 4% vanadium, 0.25% (maximum) iron, 0.2% (maximum) oxygen, and the remainder titanium.[5] It is significantly stronger than commercially pure titanium while having the same stiffness and thermal properties (excluding thermal conductivity, which is about 60% lower in Grade 5 Ti than in CP Ti).[6] Among its many advantages, it is heat treatable. This grade is an excellent combination of strength, corrosion resistance, weld and fabricability.
"This alpha-beta alloy is the workhorse alloy of the titanium industry. The alloy is fully heat treatable in section sizes up to 15mm and is used up to approximately 400°C (750°F). Since it is the most commonly used alloy – over 70% of all alloy grades melted are a sub-grade of Ti6Al4V, its uses span many aerospace airframe and engine component uses and also major non-aerospace applications in the marine, offshore and power generation industries in particular."[7]
"Applications: Blades, discs, rings, airframes, fasteners, components. Vessels, cases, hubs, forgings. Biomedical implants."[5]
Generally, Ti-6Al-4V is used in applications up to 400 degrees Celsius. It has a density of roughly 4420 kg/m3, Young's modulus of 110 GPa, and tensile strength of 1000 MPa.[8] By comparison, annealed type 316 stainless steel has a density of 8000 kg/m3, modulus of 193 GPa, and tensile strength of only 570 MPa.[9] And tempered 6061 aluminium alloy has 2700 kg/m3, 69 GPa, and 310 MPa, respectively.[10]
Pokud by se dalo dohromady 5 sad, tak mam nabidku na cenu 225-275kc/ks (dle typu)
- Dosadaci plocha kuzel s 60st uhlem - urceno pro aftermarket kola - ne OEM (kulove)
Daji se vzit ruzne delky nebo i 7mi hranne, nejlepe vychazi tento typ:
Příspěvky: 4575 1998 Integra Type-R
PříspěvekZaslal: 1.5.2013 , 13:10   Citovat
Delsi verze
PříspěvekZaslal: 6.5.2013 , 12:00   Citovat
tudy
(98973 útoků)
[ Čas: 0.0460s ][ Dotazy: 43 (0.0141s) ][ GZIP on - Debug on ]
