neobvyklé rádio - Parrot RK8200
665+1 je teď offline  665+1
PříspěvekZaslal: 27.2.2008 , 10:25   Citovat
To by mohlo být hodně zajímavý rádio. otázka, jak kvalitní bude reprodukce...
Technical and commercial specifications
Bluetooth digital car stereo and hands-free kit
* Interface :
o 2.4-inch TFT screen with 262 144 colours
o 12-key numeric keypad
o 8 control buttons + 1 rotary button
* Display :
o Phone information
o Phonebook, caller names and numbers
o Playlist, album cover, artist and title
* Audio :
o 4x45W amplifier with 20-bit DAC
o Minimal impedance of 4 ohms
o Line-out socket for external amplifiers
* Tuner :
o FM and AM bands (PO and GO), RDS
o 48 recordable stations (presets)
* Digital & analogue connections :
o Specific iPod and USB connector
o SD card reader
o Analogue jack line-in socket at the front
o Analogue RCA line-in socket at the back
* Téléphony :
o Automatic phonebook synchronisation
o Complete call records
o Number of contacts: total of 8 000
o Voice recognition
o Speech synthesis of the names in the phonebook (TTS)
* Sound :
o Full duplex and echo cancellation
o Parrot DCBM noise reduction
o Double microphone built into the front panel
o Automatic detection of the speaker's position
o Bluetooth stereo (A2DP) compatible
o Transmission through the vehicle's speakers
Bluetooth
* Bluetooth v1.2
* Profiles supported:
o HSP 1.0 (Headset Profile)
o HFP 0.96 / 1.0 / 1.5 (Hands Free Profile)
o A2DP (Advanced Audio Distribution Profile)
o AVRCP (Audio Video Remote Control Profile)
o OPP (Object Push Profile)
o PBAP (Phone Book Access Profile)
o SYNC
* Maximum range: 10 meters
* Pairing by PIN code, maximum of 10 devices
* Updates via Bluetooth
Processor
* Parrot P5+ (32 bits) @ 208 MHz
* Memory: Combo Flash = 1 GB
* RAM = 128 Mbits
Dimensions
Front panel
* Height = 59 mm
* Width = 189 mm
* Depth = 29 mm
* Weight = 0,3 kg
Unit
* Height = 58 mm
* Width = 180 mm
* Depth = 174 mm
* Weight = 1,1 kg
Kit contents
* 1 PARROT RK8200 car stereo / hands-free kit
* 1 removable front panel with screen and keypad
* 1 carry case for the removable front panel
* 1 USB / mini USB cable
* 1 accessory bag
* 1 user guide
web : Parrot UK
drone je teď offline  drone
PříspěvekZaslal: 27.2.2008 , 10:39   Citovat
mame v aute BT handsfree parot a spokojenost... ale nema to tolik funkci asi jako to radio svatoušek
Příspěvky: 2794 H+ body: 0
fun_thomas je teď offline  fun_thomas
PříspěvekZaslal: 27.2.2008 , 10:53   Citovat
Hodně zajímavý rádio je to dobrý
Video (moc toho tam není, ale pro představu):
cnet Review
Jen tam mimochodem, zajímalo by mě, jak by to fungovalo dohromady s HTC TyTN II. Ted mam sadu Parrot CK 3100 a dela to dost problemy. Musim jeste zkusit do ty sady nahrat novej firmware, ale zatim nic moc.
Příspěvky: 269 H+ body: 0 2009 Civic Type-R
tomasz je teď offline  tomasz
PříspěvekZaslal: 27.2.2008 , 11:18   Citovat
jen pro info...na trh by mělo dorazit v průběhu druhého čtvrtletí 2008 za cenu 149,99 EUR, tedy necelé 4 tisíce korun.
Příspěvky: 414 H+ body: 0 1994 Civic Coupe
Henges je teď offline  Henges
PříspěvekZaslal: 27.2.2008 , 13:21   Citovat
tomasz napsal:
Ted reším nové rádio. To si teda asi i počkám Úsměv
vojt4s je teď offline  vojt4s
PříspěvekZaslal: 27.2.2008 , 13:25   Citovat
no na parrota nedám dopustit.
Rádio sice odzkoušené nemám, ale většinu jejich produktů ano. Ve firmě se používaji jenom parroty.
Všichni známí kupujou ho. papa
v-tec je teď offline  v-tec
PříspěvekZaslal: 27.2.2008 , 19:24   Citovat
jaka bude reprodukce opravdu netusim,ale jinak znacka parrot je docela znama a kvalitni,takze bych se toho nebal
PříspěvekZaslal: 27.2.2008 , 19:30   Citovat
Libi se mi to Úsměv koukal jsem ted na to video co pridal funthomas gut
Biturb je teď offline  Biturb
PříspěvekZaslal: 27.2.2008 , 19:46   Citovat
Za ty penizky to vypada zajimeve..
Ja jsem poridil JVC AVX 33 do nynejsiho koraba muhehe a max spokojenost!! Muzu doporucit!!
kdyz tak kouknete tady...
Příspěvky: 483 H+ body: 0 1987 CR-X
[ Čas: 0.0859s ][ Dotazy: 61 (0.0082s) ][ GZIP on - Debug on ]
