P: JDM D15B VTEC 130PS *SWAP*
Zemi je teď offline  Zemi
PříspěvekZaslal: 7.6.2019 , 14:52   Citovat
Mám možnost koupit tuto raritu. Osobně nemám zájem mít jej na skladě tzn. čas je omezený.
130tkm
Fotka je aktuální.
Cena swapu 30.000,-
V PŘÍPADĚ ZÁJMU PROSÍM VOLAT 608372848
D15B VTEC
Found in:
1992–1995 Honda Civic Vti (Japanese Market)
1992–1998 Honda CRX DelSol (Japanese Market)
Bore and Stroke: 75.0 × 84.5 mm
Displacement: 1,493 cc (91.1 cu in)
Rod Length: 137 mm
Rod/Stroke: 1.63
Compression: 9.3:1
Power: 130 PS (96 kW; 128 hp) at 6800 rpm
Torque: 14.1 kg⋅m (138 N⋅m) at 5200 rpm
VTEC Switchover : 4,600 rpm
Redline: 7200 rpm
Rev-limiter: 7200 rpm
Valvetrain: SOHC VTEC (4 valves per cylinder)
Fuel Control: OBD-1
Head Code: P08
ECU Code: P08 (small case ECU)***
Found in:
1995–1998 Honda Civic Ferio Vi (EK3, Japanese market)
1999-2000 Honda Civic Vi-RS
2001-2005 Honda Civic JDM VTEC (Japanese market, Europe)
Bore and Stroke :75,0×84,5 mm
Displacement : 1,493 cc (91.1 cu in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Power : 130 PS (96 kW; 128 hp) at 7000 rpm[8]
Torque: 139 Nm at 5300 rpm
Redline : 7200 rpm
Valvetrain : SOHC, four valves per cylinder
Connecting rod length : 137 mm
Connecting rod big end diameter : 48 mm
Fuel Control : OBD2b
Head Code : P2J-07
ECU Code: P2J (small case ECU)*** AUTO CVT: P2J-J63*** MT P2J-003*** & ***MT P2J-J11***
Piston code : P2J
IMG-20190606-WA0010.jpg, 243.77 kB
[ Čas: 0.0534s ][ Dotazy: 31 (0.0050s) ][ GZIP on - Debug on ]
